TwinTurbo.NET: Nissan 300ZX forum - Re: Sounds like your timing belt might be off a tooth
Gumbercules
on August 10, 2015 at 8:24 PM
posted by Z32CheekiBreeki
on August 10, 2015 at 07:26 PM
Ok, I will check the timing again. Before I used a timing light and by making slight adjustments to the CAS was able to hit the 15° mark. Could the belt still be off a tooth and still line up in this way?
Terrible Acceleration/Throttle Response Problem
Gumbercules
17:40:33 08/10/15
Z32CheekiBreeki
19:26:11 08/10/15
Re: Sounds like your timing belt might be off a tooth -
Gumbercules
20:24:11 08/10/15
ignition timing is different from sprocket timing
Z32CheekiBreeki
22:37:56 08/10/15
Was the car like this before the T-belt replacement?
Stanky
20:29:35 08/10/15
Re: Was the car like this before the T-belt replacement?
Gumbercules
23:09:00 08/10/15
I agree with everyone here. Sounds the T is off off a tooth.
Goldchocobo
01:13:37 08/11/15
Re: I agree with everyone here. Sounds the T is off off a tooth.
Gumbercules
20:51:56 08/12/15
Check your TPS, recheck for vacuum lines for something
Goldchocobo
00:43:12 08/14/15
Gumbercules
21:14:27 08/12/15
